Results 1 to 4 of 4
Thread: White Film / residue floating on top of pool.
    Jul 2006
    Default White Film / residue floating on top of pool.
    Well i put in a algaecide last weekend didn't read carefully and put in a little too much a day later the white film / residue appeared then i backwashed and it want away then resurfaced again yesterday. now it doesn't seem to be going away backwashed just to check but perfectly clean. I don't see it but my fiance things the water coming out of the return is cloudy doesn't anyone know what this might be?
    any help would be greatly appreciated.
    Thanks,
    JIm
    tenax is offline Established User Widget Weaver tenax 0
    Default Re: White Film / residue floating on top of pool.
    any powdered chlorine? was it liquid or powder algacide? (not sure if there is such a thing but) reason i ask is because at the start of the season when i shocked with chlorine, i forgot to premix the chlorine crystals in water..dumped straight into the skimmer..had crap on my pool for at least 5 days floating on top and just kept running the pump and it finally dissolved.
    Jul 2006
    I've been using the bleach as chlorine and it was liquid Algaecide probably put a little too much in not sure what to do now.
    mbar's Avatar
    mbar is offline PF Support Team Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    If it was the algaecide, then it will go away on it's own, bump your chlorine up and it should clear faster.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
