There is only so much the plasters can do to create a even pool, take into consideration that the entire pool is Hand troweled not machined in anyway, but if its really bad and you would like to fix that i don't see any harm in sanding it, just start at the deep end of the pool so that its less noticable and where you have less of a chance to make skin contact. Perform it at a low grit and as you remove the waves go to a higher grit. Let me know the outcome.Originally Posted by HAYMAN
