Re: White foam on cloudy water
The cloudyness and CC of 1 say you're definately still fighting a load of some kind, so keep up the shock level bleach usage.
I'm wary of the "regular scent" bleach. You should only use regular bleach. No scents, dyes, outdoor formula, etc. Just plain 'ole bleach.
If you are close to a pool store that sells "liquid Chlorine" in a big jug, you may be better off that route. Its usually the 12% stuff, so compare price by volume to see if its a good deal.
Have you put any algecide or clarifier in? I know the non Poly 60 algecide will cause foam. Clarifier will cause cloudy water if over used. (I know from experrience on both counts)
Nater
