Re: Thank you pool doc!! Your the best.....
Well I have to say, today I got up early and read the Leslie's ultra bright clarifier instructions.
It said add 4 oz for 10k pool, or for really cloudy add 8 oz for 10k. So I added 6oz for my 6200 gal pool. I mixed with 2 gal water and poured in front of the skimmer slowly. ( I figure 6 oz was a good # for a cloudy 6200 gallon pool)
All I can say is I should have maybe tried this a few weeks ago
( I did add 2 oz early on, but was afraid to use more because of all the bad press here about using it.)
My theory is I just needed to use more..... I ran the pump on high with the cart and left for the day.
Came home later this afternoon to a sparkly clear pool.
Here are the results.
Pressure rose 1 psi
Total:
42 gallons of bleach, 1 box of backing soda, two pounds of CYA, 8 oz in total of clarifier, 25 days of none stop filtering, and lots and lots and lots POP!!!!! ( Pool owner patience)
And thanks to all who put up with my long winded posts. Especially Ben.
I know I was frustrated and my posts are hard to read at times when I ramble on about useless stuff.
See you all in the closing season. I am going to close the pool properly this year so I may not have this trouble next year.
P.S. Its too cold to swim...LOL ( I started early because last year it took the same amount of time to clear and all other pool owners were swimming when I wasn't)
Oh and if anyone knows finds out what the actual issue, about whatever was in my pool that was not filterable, please let me know.
Regards,
Your friend from NJ.
Mike
12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
