Thread: Best way to use DE to clear water bubbles from a sand filter pool
Threaded View
    Jun 2014
    Nashville
    Default Best way to use DE to clear water bubbles from a sand filter pool
    Through the years the pool has been balanced.. it looks cloudy and I have to use DE (diatomaceous earth) to clear the pool of those tiny micrososcopic bubbles all over. It works problem is it takes too long. Each time I add DE to the skimmer.... I add the ear and water to it and add it like 3-4 cups or less problem is it increases the pool pump pressure to nearly 30 and thus making the pump not skimming. I have to do a backwash > Rinse or even drain off the water with the DE along with it. How do I add DE without affecting the pool pump pressure. I have a 16 x 32, 23,0000, Jacuzzi Sand Filter which is like zillions of years old but it works well, Salt Water System, Chlorinator dispenser which comes in handy sometimes... what can I do to clear the bubbles which is making the pool very cloudy.. as I can see the bubbles from the underwater lights when turn on in the night. Seems like where I put the pressure clock thing has sometimes some drips of water coming out from it. Is that causing the bubbles?
    18 x 36 Liner Pool. About 1975 built in ground
    22,000 gallon, Hayward/ Jacuzzi Sand Filter
    Aqua pure Salt Water Generator, Chlorine Tab Dispenser
    1Hp super Pump
  1. Will a Krystal Clear Sand Pump and Saltwater System work for my pool?
    By inhope in forum Intex-type Pool Setup & Operations
    Last Post: 08-23-2014, 05:31 PM
  2. Replies: 2
    Last Post: 06-22-2014, 04:06 PM
  3. RE: In-Ground, DE Filter Pool With Clear Green Water
    By barbjack in forum Dealing with Algae & Slime
    Last Post: 08-11-2012, 09:48 PM
  4. Super Clear sand filter and pump
    By slssol1 in forum Pool Equipment & Operations
    Last Post: 06-20-2012, 11:46 PM
  5. Fiber Clear Water Polish for sand filters
    By mer1844 in forum Pool Equipment & Operations
    Last Post: 08-04-2006, 09:53 AM
