Could be over-watering or underwatering. Or chems are leaking.
What does "winterized 5 gallon chlorine baking soda" mean?
winterized 5 gallon chlorine baking soda last weekend
got some very unseasonal hot days and very windy on fri 80 k wind burst
now today sun noticed that 2 3 ft away from the 18in of river rock around the pool the lawn is turning yellow
winterized the local pool store told me to pour in 5 gal of chlorine and some backing soda
and algizide
Without current water test numbers, "some baking soda and algaecide" doesn't really mean anything to us. Are you asking if those are the reason why the lawn is turning yellow?
pool is closed and covered up was just wondering if the chlorine gas building up under the cover would cause the lawn to turn yellow
as after it was covered up we had a couple of 85 degree days (very unseasonal)
cholrine 5 gal
algized 500 mil
baking soda 2 500 mil box's
oh yeah lawn is watered with a inground sprinkler system on a timer set for ever 3 days for 2hrs a zone
recomended by a landscape company
I don't think you could have any kind of chlorine gas building up under the cover that would turn your grass yellow. It's possible that you could have a leak in the pool somewhere, and that the chlorine in the water that has leaked out might turn it yellow, but if that were the case I would expect to just see it in the area near the leak, not all the way around the pool.
I have seen this before, but it was due to the lawn maintenance guys spraying roundup around the pool. The overspray got the nearby surrounding grass.
thx for your help
found the source of the prob grass trimmer gas line sprung a leak and i was leaking gas that got on my shoes so now that it has rained grass is turning yellow every where i walked
