Re: Testing a SWG Pool
O.K. I just have to ask some very simple and basic questions. When I first got my SWCG it was loaded with features and display readings that I didn't understand at first. The owner's pamplet was no real help and I had to call the company to get instructions on how to set the unit up.
So are you sure the SWCG is actually running?
Mine has an Internal timer that can be set to any time of the day or night and also has the ability for the internal timer to be completely shut off and controlled by an external timer. If you look at your display does it give an output percentage? Mine can be adjusted in 10% increments from 10% - 100%
What is your set at?
If your pump is running, but the display says "IDLE" or "OFF" the SWCG is not producing chlorine. If my pump is running outside of the Internal time setting for the SWCG to be "ON", I get the "IDLE" message on the display.
The Housing on my unit has a blue plastic where the cell is and you can see the water running through it, but more importantly you can see the bubbles forming on the cell telling you that the unit is generating chlorine.
Can you see the water in your cell and the bubbles when the pump is running? No bubbles = no Chlorine.
My SWCG has a SuperChlor button. When I push it, it turns the SWCG on its max output. Does your unit have this button? If so, what happens when you push this button?
