Thread: Bleach-How long to wait to swim?
    Default Bleach-How long to wait to swim?
    My salt clorinator is not working, and I am waiting for a part. If I use bleach for my temporary chlorine solution, how long do I need to wait to swim after adding bleach, assuming I am not shocking, but just trying to maintain chlorine?
    My pool is about 20,000 gallons and CYA is about 50. I have read that 1 gallon of 6% bleach would raise chlorine by about 3PPM. Does this sound right?
    How much chlorine should I add daily? I have a test kit, but I want to start with a good estimate.
    PH is 7.6, Alkalinity 100, Calcium 225, CYA 50, Chlorine 1.5
    Thanks,
    Dan
    aylad is offline SuperMod Emeritus Vortex Adjuster aylad 4 stars aylad 4 stars aylad 4 stars aylad 4 stars aylad 4 stars aylad 4 stars
    Default Re: Bleach-How long to wait to swim?
    You are correct...in a 20K gallon pool, one gallon of 6% bleach will raise your chlorine by 3 ppm. With a CYA of 50, you need to maintain a chlorine level at all times between 3 and 6 ppm. You don't have to wait long at all after a bleach addition to swim--just make sure that the bleach is dispersed by stirring it around or pouring it slowly into a return stream, you just don't want bleach "pockets". In fact, last night I added some bleach to the deep end while the kids were in the shallow end, but by adding it into the return it mixed quickly. I did not let them swim with open eyes underwater, but otherwise it didn't bother them. It is not what I would recommend for you or any others, but at the time the situation called for it.
    Having said that, I would think that 15-30 minutes would be plenty of time to wait.
  1. how long to wait
    By cloudy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-11-2010, 10:27 PM
  2. cyanuric acid - how long to wait to swim
    By endeavor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2006, 10:20 PM
  3. Animal Poo and How Long to Wait
    By SoCalBoo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-12-2006, 04:44 PM
  4. How long to wait to swim after adding cya?
    By JJParrish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2006, 03:19 PM
  5. how long to wait to shock
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 10:49 PM
