You are right ChemGeek. On my kit 100 is an inch or so up from the bottom then the measure marks start. And you are right WaterBear the marks are not linear. So I should have diluted. Now, you mentioned using distilled water. Why can't I use tap water? Tap water should not have any CYA...should it?
Thanks guys.
Jim
