Results 1 to 10 of 44
Thread: Metal in pool
    Jun 2010
    Smile Re: Metal in pool
    ummmm...figures.. Will I glow if I swim in it? lol
    When my pool water turned brown this last time that's when it got cloudy. It turned brown cause my husband added shock and chlorine granules w/in a matter of a few hours.. That was before i added the rest of oxalic acid 16oz and 16oz of United chemicals Metal treat(Tricurboxylic Acid/Phophonbutane).
    How do I not get my water to keep turning if I'm not adding a metal treat prevenative dose.( I know I over did it)
    But I got my chlorine level to hold for 4 hours the 1st time of my pools life.
    pH 7.2
    TC 1
    FC 4
    Default Re: Metal in pool
    Hi NPG;
    When you have iron in your water, turning brown is what it has to do before you can get it out. Brown iron is the filterable form!
    What you could do is drain, refill, and add polyquat as you fill to prevent algae, etc. Then gradually chlorinate with calcium hypochlorite added to the skimmer (I can't remember, do you have a skimmer?) in small doses.
    This while STILL cause it to turn brown, but hopefully, you can filter it out as it does.
    If not, the other option is to chlorinate, let it all turn nice and brown, then turn the pump off and let it settle. Then, siphon vacuum it off the bottom and out of the pool. Of course, you'll have to refill some after you do, but you might be able to fill to flooding if you are planning to do this, and then vacuum down to normal levels.
    Ben
    "PoolDoc"
    Jun 2010
    will the sand filter catch this brown?
    It should.
    AG pool filters tend to be undersized, and the pumps oversized. Your filter will perform better if you can throttle the flow back some.
    Ben
    "PoolDoc"
    Jun 2010
    i don't know what throttle the flow means, but wish me luck.
    Jun 2010
    I just wanted to thank you all for your help. If it wasn't for all of the support and knowlege from this forum I would have never had a clear pool. It took a while and alot of vacuuming, but I am finally able to swim in a clear pool. I am even able to shock w/o dealing with brown water. I love the BBB method, and all of your other tips and tricks. This forum is amazing. Keep up the good work.
    Thanks again,
    Kristy
    Thanks for the update!! We always like to hear about it when you finally reach the end of that long road and find out that you CAN have a clean, clear pool.
    Happy Swimming!!
  1. Drain12 ft. Metal Frame Pool
    By TheKs in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2012, 07:57 AM
  2. Texas Plaster Pool Metal Stains
    By Captain Ron in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-17-2012, 06:07 PM
  3. looking for info on getting the metal out of our pool
    By brennac in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-10-2012, 11:00 PM
  4. Metal in the water (Fiberglass 35K pool)
    By blk133 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-19-2006, 02:36 AM
  5. Intex Metal Frame Pool
    By SBaker in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2006, 11:48 AM
