Results 1 to 10 of 62
Thread: Cyanuric Acid
    Default Re: Cyanuric Acid
    You can always add a little DE if you want--just enough to make the pressure rise by 1 ppm--and it may help filter out smaller stuff. Don't forget that the pressure rise takes a few minutes though, so add it slowly.
    I don't think adding floc is going to help--it is designed to make smaller particles that won't settle to the bottom stick together so it will settle. Sounds like yours is settling fine, so there's no need for the floc.
    Good job getting the CYA down to 50--now just maintain your chlorine in the 3-6 ppm range. Actually, I would keep it on the upper end of that, but it should be easier to maintain your pool now.
    You can always add a little DE if you want--just enough to make the pressure rise by 1 ppm--and it may help filter out smaller stuff. ...
    Janet means 1 psi, not 1 ppm. (Pound/square inch, not parts per million).
    oops, yeah--thanks for catching that for me!!
    Sue225 is offline Subscriber Thread Analyst Sue225 0
    Jun 2010
    NW Indiana
    I added about 1 cup of de to sand filter and it appears to have blown into the pool. Is this normal? Also, the pressure never went up. Should I add more DE?
    It is not normal for the DE to blow into the pool. Did you add it slowly through the skimmer? It should have gone in and coated the sand but not gone through it. How long has it been since you backwashed the filter? Sounds like maybe the sand in your filter is "channeling"--that sometimes happens with very old sand or with a pump that is too big for the filter, where it creates channels in the sand. That might explain why it's not filtering the "brown stuff" out to begin with. Have you checked to see if the "brown stuff" is gritty, maybe it's sand blowing back into the pool?
    If you haven't backwashed lately, go ahead and backwash well, then rinse well, then put it back to filter and try a little more DE. I think I'd start with about 1/3-1/2 cup, though, just in case it blows through. If it blows through this time after backwashing, then you've got filter issues that need to be resolved.
    Jun 2010
    NW Indiana
    I have suspected, since I subscribed to this forum, that our pump is too powerful for our filter. 1 1/2 HP pump for Silica I filter. 24 round UG pool! Our pressure never goes up and very little dirty water is backwashed out. Of course, my husband doesn't want to hear it but I am pretty sure this is the problem. The brown stuff is definately not gritty.
    We replace the sand every summer. At the end of the season it is white as snow, normal?
    Your thoughts appreciated
  1. No Cyanuric Acid?
    By Strongmad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2012, 11:21 AM
  2. Can't get cyanuric acid to register
    By rickwray in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2011, 08:58 AM
  3. cyanuric acid
    By kickurasin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2007, 11:23 AM
  4. Cyanuric Acid
    By golfwig in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2006, 03:30 PM
  5. where to get cyanuric acid?
    By fog80 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-07-2006, 09:22 PM
