Results 1 to 9 of 9
Thread: Silt on Steps and Outs
    Texas
    Default Re: Silt on Steps and Outs
    Thanks for the rely.
    I guess I need to learn how to vacuum to waste.
    All I have is a connector in my skimmer for the hose (I've never used it). That's going back into the system, not to waste. (unless I don't understand what 'vacuum to waste' means)
    Do I do this while backwashing?
    Texas
    A quick search tells me some backwash valves have a 'waste' setting.
    I have a simple Jandy push-pull backwash valve, it's either up or down. Is there a way to do a 'waste' setting with this type of valve?
  1. Cleaning up fine dirt or silt
    By waldreps in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-21-2012, 09:17 AM
  2. sand/silt in pool
    By uaguyua in forum Pool Equipment & Operations
    Last Post: 03-19-2012, 07:07 AM
  3. Silt on pool bottom from filter
    By maryberrye in forum Pool Equipment & Operations
    Last Post: 07-04-2011, 05:25 PM
  4. Polaris foam tail scrubber -- cheaper source?; Silt bag tip
    By tsuma in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-02-2008, 01:31 PM
  5. Should I use Alum to get rid of silt and mud
    By Amir in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2006, 01:39 PM
