If you are going to add the cya to the skimmer, wait to add it until your water clears up because if it is still cloudy, you will most likely be backwashing and you'll just lose the cya. Wait until water is clear to add it to the skimmer OR add it in front of a return jet (in an old sock) and then the backwashing is no longer an issue.
