PoolDoc
On my way out the door for some 'volunteer' duty at Chattanooga's Riverbend -- heat index 104 and climbing! (Yuck, yuck, yuck)
But, if you don't want to drain, you just need to uncover and filter and clean.
If your OTO is clumping into brown particles, the chlorine level is REALLY high. Everything is dead and/or oxidized. Polyquat would be completely useless at this level of chlorine.
Don't worry about any other test results -- they wouldn't likely be valid anyhow.
Sunlight, filtration, cleaning . . . and patience: LOTS of patience. Many pool owners get to this point in clearing their pool, and then -- under the influence of the urge to DO SOMETHING! -- make it worse. Do NOT add stuff you don't need; do NOT do something that won't help.
If you can't drain, you must filter and with an inadequate filter, there's really no way to speed that up. But there are many, many ways to slow it down, and your neighborhood pool store will be very happy to sell you some of them.
Good luck
PoolDoc
