Hey MJA,
I am also a local. About 10 miles as the crow flies across the bay in NJ. I run a 1hp pump on a 33,000 gallon IG pool. Just replaced my 11 year old Hayward pump motor. That job was hot and heavy, literally. Anyway, you could be pulling it in and blowing it through, over and over. Wait 'till you deal with dead algae with a sand filter. PITA! Easy enough to fix though. Just vac to waste next time. Even with only a few minutes you will be able to get the dirt out and skip the filter altogether. If it re-apears, it is not a pump motor filter ratio issue it is just a "this is what is in the air here" issue. I get that a lot early season and dry weather. Later, for no explainable reason it stops? But the other stuff starts up, helicopters, Wisteria pods, you name it. The folks here are a resource you should appreciate completely, and I do not over-state this. Been care-taker of a pool, on and off for a combined 3 decades. Until PF I still thought pool stores had a use other than parts.
