Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: Chem Geek or Mbar - are you there? Iron test question.
  1. #21
    labdi01 is offline Registered+ Thread Analyst labdi01 0
    May 2010
    Default Re: Chem Geek or Mbar - are you there? Iron test question.
    That's a lot of math, Chem Geek!
    We do have staining - but we had a brown pool over the course of several days - on 2 separate occasions.
    5 was the highest reading we'd gotten. Right after we filled and it turned brown, it was only a 3. It couldn't have gone up 1.5 times when significant amounts of new water hadn't been introduced. So, I agree with you CG - it is suspicious. Not to mention the fact that the boy who did the test looked all of 12.
    I no longer have the desire to know what the iron level is. I think I was just caught up in it because we fought it for several weeks. Truth is - it's not interfering with anything right now, so who cares. If water turns, I'll filter it out again. Done. Moving on.
    Thanks for putting up with my neuroses!
    Dianna
    New owner of 24' above-ground pool, vinyl liner, 1 hp pump and sand filter, added D.E.
  2. #22
    Sounds like you have a good handle on your pool at this point. Time to move on and just enjoy it now. Don't fret over every little speck or your pool will end up being all work and no play. Glad Pool Forum was able to help you. Now time for you to go have fun! Good luck.
  3. #23
    May 2010
    Thanks Watermom.
    The forum has been vital to our success. I'm sure I'll have other things crop up - but for now - we're almost there!
    Dianna
  4. #24
    mbar's Avatar
    Ashland, PA
    You may not be a chemist, but I would trust you in any chemistry questions that come along Chem Geek
    Hey my picture turned up!
    Northeast PA
  5. #25
    mbar's Avatar
    Ashland, PA
    This is the first time I saw it, but I tried to upload it a couple of days ago, and it says it failed
    Northeast PA
  7. #27
  1. Aqua chem 3-way test kit instructions
    By FNC1962 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2012, 12:11 PM
  2. Calling All Chem Geeks (incl. THE Chem Geek) re: storing pool chems
    By elsie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2011, 10:20 PM
  3. Ascorbic Acid Treatment - MBAR's suggestion
    By jimmysam in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-02-2010, 08:01 PM
  4. Trying to keep up w/ Chem Geek
    By ShelleyAnn in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 03:30 PM
  5. hth and aqua chem test kits
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-09-2006, 03:33 PM
