Results 1 to 4 of 4
Thread: reuse liner
    Jun 2010
    southern in.
    Default reuse liner
    is it possible to reuse a liner that is 1 year old when i move my pool.
    Default Re: reuse liner
    Normally once the pool is drained, the liner shrinks and is not useable again. Maybe one of the liner/construction gurus can comment further, but I think you're going to have to replace it.
    Welcome to the forum!
    A one year old liner should retain it's elasticity enough to enable you to reinstall it - however, it's best to be prepared to have to buy a new one.
    Sacramento
    Have not been by here in a while. How did the pool move go? Perhaps you've found that the biggest problem would have been to get the "holes" (skimmer, returns) lined up. Often, an easier solution is just to put a patch over the existing holes and line them up with the patched piece. Trying to use the same holes will often result in the liner tearing out at those spots as it is filled. Sorry if I'm too late...
  1. J-channel holding liner in corner broke off, liner is sagging
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 04:41 PM
  2. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  3. Do I need "Liner Lock" for Beader Liner
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2006, 12:04 AM
