Results 1 to 10 of 45
Thread: Ordered My Pool
    Jun 2010
    Default Re: Ordered My Pool
    Just wanted to give a quick update.
    Pool water is still sparkling. I'm down to adding about 2.5 quarts of bleach a day. It usually ends the day at about 1.2 to 1.6, and we've been bumping it up to 4.0 ppm. CYA should be nearing 30. I've used 2 trichlor pucks this week to pump it up a bit more. I'll probably test it at the end of this week, backwash, and then add the remaining amount.
    However, I'm fairly sure that the pool has a small leak. As I mentioned before, the liner slipped when we were filling, so the sand underneath became quite wet.
    Each morning, there is a wet spot around a section of the pool. At first, we had hoped it was just the weight of the pool pushing the water out of the sand underneath, but it's continued for a couple weeks now. I'm not losing much water, because after considering evaporation, there can't be much water. I guess I need to do the bucket test to compare evaporation for a couple days to know for sure. Not sure how we would've gotten a hole in the liner, but I guess it's possible.
    Beyond that, we've been enjoying the pool, and it's staying nice and clean and clear. I did manage to swim enough to get swimmer's ear, so that's fun. I'm out of swimming commission for a few days, but I'll be back at it soon enough.
    Thanks for all your help folks.
  1. Just ordered new AGP. Startup suggestions?
    By Bluemackie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2012, 12:33 PM
  2. Pool is ordered!
    By swimlane in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2011, 10:05 PM
  3. AutoPilot Question (just ordered)
    By jmcst25 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-29-2007, 01:26 PM
