Results 1 to 10 of 16
Thread: Ascorbic Acid Treatment
    Jun 2010
    Central NY
    Default Re: Ascorbic Acid Treatment
    Here are the numbers that we got from having the water tested:
    Free Available Chlorine .2
    Total Chlorine .2
    Total Alkalinity 103
    ph level 7.2
    calcium hardness 23
    Cyanuric Acid 99
    copper .4
    we were told (by pool store person) that we needed to drain 1/3 of pool to get the cya level down and add calcium. Then add more stain out. Does this sound right? Of course, everytime we talk to someone else, there are more chemicals and lots more $!!! Thanks for all of your help!
    Pool Info: inground 16,000 gallons, sand filter
    mbar's Avatar
    Ashland, PA
    It does sound like you need to get your cya down. This is what I would do first:
    Drain and refill about a third of the water.
    Add calcium to get it up to 250 - 300
    Keep your ph at 7.2
    add bleach to get your chlorine up to the best guess chart of chlorine and cya that is in the sticky in the chlorine forum.
    Add the bleach slowly - one jug at a time
    If you see stain start to come back, then add more sequestering agent.
    If the stain persists more than a day after the sequestering agent, and your ph is still no higher than 7.4 add more ascorbic acid (or citric acid).
    Keep the pump running 24/7.
    I think after doing this the water should be fine - whenever you get high chlorine along with high ph and there are metals in the water and not enough sequestering agent the metals will fall out and stain the surface of the pool. If you have metals it is always a good idea to keep the ph around 7.2. I always use the sequestering agent first before any stain treatment because it will generally lift any new stains. Let me know if you have any other questions.
    Northeast PA
    Jun 2010
    Central NY
    Thank you so much for all of your advice...the pool stores have no idea how to handle this! My other question is about the best guess table...I am not sure how I should be reading it. Any help with this is appreciated greatly! Thanks!
    The best guess table is to help you determine how much chlorine you need to maintain in your pool all the time, and how high to shock the pool when that is needed. It is based on the cya level in your water. For example, if your cya level is 40ppm, then you must keep your chlorine between 3-6 all the time and if you need to shock, you will need to take the chlorine level up to 15.
    Does that answer your question about the table? If not, repost with a more specific question and we'll try again.
    Jun 2010
    Central NY
    Yes, that answers my question about how to read the chart. Right now my cya is high and I have to get it down, but not sure what number I am suppossed to be getting it down to.
    Jun 2010
    Central NY
    currently it is 99...that's why we need to get it down
    mbar's Avatar
    Ashland, PA
    Anywhere between 30 - 50ppms
    Northeast PA
    Jun 2010
    Central NY
    After draining 1/3 of the pool and refilling (twice!) we still only got the cya level down to 76. With the FC down to 0 we used a stain out product and then a metal out product. The pool looked great...until we added chlorine back in...now all surfaces are stained again. This is the 2nd time we have done this whole process and while the copper has gone down from .4 to .1 we still can't seem to get it out. The stain out and metal out are pretty expensive and we don't want to keep having to use them. Our public water has no copper in it...we think it must have come from algecide that the pool openers used. How can we get better results that will last? Can we ever totally remove the copper...or will we eventually have to drain the entire pool? We feel like we are going to be battling this forever and we don't want to keep throwing $90+ away everytime we try to treat the problem. Any advice would be appreciated, thanks!!!
    -16,000 gallon inground pool, with vinyl liner & sand filter
    May 2010
    I was in the same boat as you and have tried just about everything... My CYA is higher than yours (100) and here is what I have done with the best results. (Dumping water was not an option)
    If your water is clear, stop feeding chlorine and let the levels come down to 1 ppm or so. For your amount of water, get about 2 lbs of ascorbic acid and two bottles of ProTeam Metal Magic. When the chlorine drops, bring the pH up to around 7.6-7.8. With the pH correct, add the ascorbic acid it the skimmer. Let the acid circulate for a couple of hours or until the stains have disappeared. When the stains are gone, add two bottles of Metal Magic. Wait 24 hours and then start to bring the chlorine up. Do not add any shock or liquid chlorine. If you have a feeder, put it on its lowest setting. If you put tabs in the skimmer, just keep an eye on your chlorine levels. You do not want to go higher than 2-3 ppm. If you have high metals, every week, you will need to add metal magic.
    I have been fighting this all summer and so far this has been the best. The ascorbic is expensive but the Metal Magic is $17 at my local store. I feel somewhat stupid because I am a water engineer and this has been the hardest thing to deal with.
    Give it a try and let me know how it goes.
    Regards,
    Chris
  1. ascorbic acid treatment
    By pooltech in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 10-30-2012, 06:59 PM
  2. Ascorbic acid treatment
    By TLMMommy in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-05-2012, 12:54 PM
  3. Ascorbic Acid Treatment
    By Phenom300 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2012, 11:18 PM
  4. ascorbic acid treatment for my pool?
    By masspool in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-27-2008, 01:13 PM
  5. HELP - Ascorbic Acid treatment - I have a problem
    By gerri in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-15-2006, 09:10 PM
