Results 1 to 10 of 16
Thread: Ascorbic Acid Treatment
    Default Re: Ascorbic Acid Treatment
    Hi, and welcome to the forum!! Just start adding the chlorine slowly, watching for signs of staining. If you see them, add more sequestrant. If not, just slowly raise it to whatever your target Cl is, based on your CYA level (see the Best Guess Chart stickied at the top of the Chlorine forum). It may take a good bit of chlorine to get back up there, my understanding is that both the sequestrant and the acid eat up a good bit of it. Most of us on this forum use plain, generic, unscented bleach for chlorine--12.5% liquid chlorine is not available in my state, but others on the forum prefer to go that route...
    Jun 2010
    Central NY
    I added a small amount of chlorine last night and by this afternoon I already see the staining returning! I am so frustrated by this. I guess that means I need to add more sequestrant, but my question is how often will I need to do this? I am on city water and don't have a heater...I can't figure out how metals could have gotten in the water in the first place. Any help would be greatly appreciated.
    You may have to add sequestrant each time you add water. Marie, our metals expert, can better advise you. She'll be popping on here at some point and I'm sure will take a look at this thread. Hang in there ........
    mbar's Avatar
    Ashland, PA
    If you give us a full set of numbers we can help you. Sometimes the water needs to be balanced before the stains will stay away.
    Northeast PA
    Jun 2010
    Central NY
    Here are the numbers that we got from having the water tested:
    Free Available Chlorine .2
    Total Chlorine .2
    Total Alkalinity 103
    ph level 7.2
    calcium hardness 23
    Cyanuric Acid 99
    copper .4
    we were told (by pool store person) that we needed to drain 1/3 of pool to get the cya level down and add calcium. Then add more stain out. Does this sound right? Of course, everytime we talk to someone else, there are more chemicals and lots more $!!! Thanks for all of your help!
    Pool Info: inground 16,000 gallons, sand filter
    mbar's Avatar
    Ashland, PA
    It does sound like you need to get your cya down. This is what I would do first:
    Drain and refill about a third of the water.
    Add calcium to get it up to 250 - 300
    Keep your ph at 7.2
    add bleach to get your chlorine up to the best guess chart of chlorine and cya that is in the sticky in the chlorine forum.
    Add the bleach slowly - one jug at a time
    If you see stain start to come back, then add more sequestering agent.
    If the stain persists more than a day after the sequestering agent, and your ph is still no higher than 7.4 add more ascorbic acid (or citric acid).
    Keep the pump running 24/7.
    I think after doing this the water should be fine - whenever you get high chlorine along with high ph and there are metals in the water and not enough sequestering agent the metals will fall out and stain the surface of the pool. If you have metals it is always a good idea to keep the ph around 7.2. I always use the sequestering agent first before any stain treatment because it will generally lift any new stains. Let me know if you have any other questions.
    Northeast PA
    Jun 2010
    Central NY
    Thank you so much for all of your advice...the pool stores have no idea how to handle this! My other question is about the best guess table...I am not sure how I should be reading it. Any help with this is appreciated greatly! Thanks!
  1. ascorbic acid treatment
    By pooltech in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 10-30-2012, 07:59 PM
  2. Ascorbic acid treatment
    By TLMMommy in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-05-2012, 01:54 PM
  3. Ascorbic Acid Treatment
    By Phenom300 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-21-2012, 12:18 AM
  4. ascorbic acid treatment for my pool?
    By masspool in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-27-2008, 02:13 PM
  5. HELP - Ascorbic Acid treatment - I have a problem
    By gerri in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-15-2006, 10:10 PM
