Results 1 to 10 of 36
Thread: New Pool Owner With High Iron Manually Removing Iron
    mbar's Avatar
    Ashland, PA
    Default Re: New Pool Owner With High Iron Manually Removing Iron
    Yes, I agree that the greenish tint to the water is metals - think of it this way, when the metals are yellowish brown and the pool water is blue, yellow and blue make green I see this in my pool all the time, that's how I know to add more sequestering agent. When my pool is clear but not quite blue blue it is because something is going on As for the cya - sometime when using a lot of sequestering agent it uses up cya. I am not a chemist, and I don't know the reason, but I do know this from experience. It can also use up a lot of calcium too. Just as I said, every time you add something to the water it changes something else Once the water is balanced (and metal free) it is easy to keep it up, but sometimes getting there is a big pain. Everyone's water reacts differently, because what is in the water is different than anyone else. This is why when you learn to care for your own pool it makes it easier - because the pool store is giving out information on a all encompassing situation, as well as selling chemicals. Keep up the good work, and keep us informed - I love your idea!
    Northeast PA
    labdi01 is offline Registered+ Thread Analyst labdi01 0
    May 2010
    I can't believe my iron is 0.
    Of course, with all the backwashing this weekend, I need to fill up again (from the iron-laden well), but I'm going to do it today while the homemade filter continues to run, and as an added precaution, my husband filled another bucket with quilt batting and I'm going to attach a prefilter to the hose and stick the filter into the batting bucket and hang that in the pool as it fills.
    We did a test in a bucket on Fri where we double-filtered the fill water (hose prefilter and Slime Bag over that) and then added bleach to the filled bucket - turned brown.
    I can't believe how cheap and easy the successful course of action was. A bucket and sump pump that we already had, $16 worth of quilt batting (no longer suggest the loose stuff - makes a mess) and 72 hours!
  1. Iron out to treat iron and tea colored water
    By Fornetti in forum --cleanup--
    Last Post: 07-02-2013, 03:56 AM
  2. Which filter/pump better for water with high iron
    By tsybert in forum Intex-type Pool Setup & Operations
    Last Post: 06-21-2012, 10:00 PM
  3. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 03:58 PM
  4. New Pool Owner With High Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-08-2010, 06:11 PM
  5. Does Zeolite help in removing iron from the water?
    By smallpooldad in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-26-2006, 05:23 PM
