Results 1 to 10 of 14
Thread: Help - Need information for wiring for an AGP
    Honesdale PA
    Default Re: Help - Need information for wiring for an AGP
    Welcome to the forum. First comment is the 1 HP pump is way too oversized for the 100# sand filter no matter what the motor rating. Full or uprated. You don't say if the motor is 120 or 240 V. If it's 120 the 15 amp breaker would be marginal and I'd go to 20. The running current on a 1 HP is around 7 amps at 240. I'd also go with a GFI breaker. For the 60' run with #12 the total resistance is about 0.2 ohms so at 7 amps you would drop about 1.4 volts. No big deal. Go with #12. Electricians speak their own language. I'm not an electrician. As for the types of wire suitable for conduit, ordinary romex should suffice since it won't be exposed to dirt or dampness. As for a timer, the mechanical types can be used as a switch too but I'd put in a separate switch to keep the pump off if you desire.
    Now...a word of warning. I hate codes. Whatever I said above may be overridden by local and national codes. I don't know what they are. I've given practical info above as a DIYer myself who lives in an area where even pool fences aren't required. People do have them though to keep the big critters out.
    I'm feeling a little whacky tonight but seriously, check your codes and follow them. Oh, that pump/filter sizing should be addressed further.
    PS: OK Carl, Chastise me about codes.
    Just to give you some perspective on pump/filter sizes: I have a 24 ft AG and I have a 1/2 hp pump and a 200 lb. sand filter. I agree with Poconos. Your pump and filter are mismatched. A pump that is too powerful for a filter can damage it. I'd take it back and get a smaller pump and a larger filter.
    May 2010
    If any one out there is a licensed Electrician, Please feel free to chime in. I am not a licensed Electrician.
    The only thing I want to caution you about is running Romex through Conduit. In most cases, it is a no-no for two reasons. 1) Even if you use 3/4 or 1 inch conduit, you will have a mountain of trouble getting the #12/2 with Ground Romex thru the conduit around the bends and turns. 2) Is Heat. When an electrical circuit is overloaded, the wires get hot and can melt the insulation. When the wires get too hot, they can ignite the insulation and result in a fire. The copper wires do not burn, it is the insulation that burns. Romex inside of conduit does not disipate heat as well individual strands. Three individual strands of #12 wire may cost a couple of bucks more than Romex but it is worth it for safety.
    Any Hardware Store or Electrical Supply House will have 12 gauge wire in Individual strands in Red or Black, White, and Green colors. Always always always install one, and only one Ground Fault Circuit Interupter (GFCI) in the Curcuit. You can install a GFCI Breaker in the Breaker Panel OR a GFCI Recepticle in the Outlet box, one or the other, never both. Two GCFI's in a single circuit will fight each other, continually trip each other, and will cause nothing but trouble for you. I also recommend a water proof Outlet box with an approved cover.
    For a 60 foot run, 12 gauge wire with a 20 amp Circuit Breaker is minimum, adequate, but minimum. If at all possible, run a dedicated line, meaning, there are no other outlets on the line from the breaker panel to the final GFCI Outlet, and I don't see a need for a switch in the circuit. A 15 amp circuit is too small and could cause pre-mature pump motor failure.
    I strongly recommend hiring a Licensed Electrician and get a building permit.
    Just trying to help! BTDG
    In most areas, if you are supposed to an electrical building permit and you don't, your HO insurance won't cover an accident.
    It's a false economy.
    With your run, you may even go to #10 wire. Plus you should absolutely go with a GFCI breaker--that protects the whole circuit, not just the outlet. Again, the $20 or $30 more is cheap insurance.
    There is also available ground contact wire which does not, I believe, require conduit. It's designed for wet and outdoor environments where the outer sheath is molded around the inner conductors, not just a shell around them.
    Electricians do this stuff all the time--it's a regular part of their business. Find a good one.
    BTW, Poconos and W'mom are spot-on about the pump and filter.
    Honesdale PA
    That wire you refer to is UFB underground direct burial. That's what I've used. I also use #12 out to the poolhouse and that run is over 100' from the main breaker panel.
    Jun 2010
    Pittsburgh PA
    I wanted to thank everyone for the advice! I am going to go to the place I bought the pool and talk with them about downsizing the pump (from the 1hp). The pump came as part of a package and I am suprised that they are including an oversized pump.
    I am also going to call an electrician (no insurance issues), its better to be safe than sorry.
  1. Great Information
    By jjsherm in forum General Interest
    Last Post: 06-04-2013, 09:26 PM
  2. New Member Information
    By BWConner in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 02:25 AM
  3. Needing some more information on UV
    By fchapma in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2011, 08:58 PM
  4. Information, please?
    By TX Daisy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-06-2006, 12:34 AM
