The reason that your post didn't seem to register at first is that Ben is updating the privileges for the various user groups. Restricted users will have to have their posts "moderated" which means that after you post, it won't show up immediately. Not until after one of the moderators validates it. If you go ahead and subscribe or become a supporter, your posts will not need to be moderated and you'll also have several other features enabled that restricted users don't have. (Including the ability to post photos which you currently don't have.) More info about this can be found here:
http://www.poolforum.com/pf2/showthread.php?t=9755
Hopefully, you have found our forum really helpful and will want to either become a subscriber or a supporter and stick around here with us!
At any rate, glad you are doing so well with your conversion. Aren't you glad you went ahead and did it? You are going to be much happier with a chlorine pool than a baq pool.
Yes, stabilizer helps to protect your chlorine from the sun. I would advise you to go and read the stickies at the top of each of the "Pool Water Treatment: Testing and Problems" sections of the forum. There you will find most of the pool care chemistry basics information. After reading, if you still have specific questions, let us know.
