Just know when you go into this that your pool is going to turn some very different, sometimes scary colors. Just stick with it, keep it at shock level (15 ppm) as consistently as you can, and it will all be over soon!!
The pressure on your filter will probably rise pretty often due to the bacqua-goo that collects, so keep an eye on it and backwash it as needed. Also keep in mind that your pH readings will be off with the high amounts of chlorine you're using--usually read falsely high, so I wouldn't do any adjusting until later on, as long as it's above 7.0. Keep the pool at shock level until you're not losing any chlorine overnight and the pool is clear--then add your stabilizer, let your Cl drift back down, and change your filter media, and then you'll be in business!!!!
