It's not uncommon for people to go through 25-30 gallons or more of 6% chlorine (bleach) to get through the conversion. You will definitely need a test kit that measures FC and CC (or FC and TC).
You won't regret it, I promise!!
picked up test kit and 24 gallons of 12.5% liqiud cl
just added 3 gallons and we have brown! - its working!
I am getting ready to dive into the test kit instructions so I can test accuratally, looks a little overwhelming at first but I am sure I'll get the hang of it.
Anybody else who has gone through this in the past, please chime in with any tips or suggestions.
Thanks again!
Just know when you go into this that your pool is going to turn some very different, sometimes scary colors. Just stick with it, keep it at shock level (15 ppm) as consistently as you can, and it will all be over soon!!
The pressure on your filter will probably rise pretty often due to the bacqua-goo that collects, so keep an eye on it and backwash it as needed. Also keep in mind that your pH readings will be off with the high amounts of chlorine you're using--usually read falsely high, so I wouldn't do any adjusting until later on, as long as it's above 7.0. Keep the pool at shock level until you're not losing any chlorine overnight and the pool is clear--then add your stabilizer, let your Cl drift back down, and change your filter media, and then you'll be in business!!!!
thanks for the ecouraging words! Ill have to run to the hardware store to pick up a new pressure guage, as mine has been toast for two years now.
I plan on testing every two hours and adjusting as needed.
Now I just need to find a magnafying glass to read these test kit instructions.
Can you add too much liquid cl in the begining?
Not that I plan on it, just curious.
I think that the Baq pretty much uses up the chlorine in the beginning as fast as you put it in the pool--but just to be on the safe side for your liner's sake, I think I'd keep it at no higher than 15-20 ppm.
thanks, I think I may need more liquid cl before monday when the pool store opens, can I use the liquid bleach in the meantime if needed?
just tested after adding 3 gallons of liquid cl no trace of cl, I must have lots of baq junk in the pool that the cl is attacking.
I added 4 more gallons and will test in an hour or so.
Again I am very greatfull for everybodys help, it makes this a lot less stressfull.
Thanks,
Bill
Bleach is the same thing as liquid chlorine, just don't get the stuff that's scented or with extra additives. Pool store liquid chlorine is 12.5 %, regular bleach is 5.25%, and ultra is 6%. I use the generic bleach from WalMart almost exclusively in my pool.
