Re: first readings!
PBLsQuad450
Yes. Reagents are R-0001 and R-0002. No powder. So, if the directions are wrong, what am I testing for first? Is it FC (with 0001 and 0002) then CC (even though that's not what the directions say) with 0003? And, is this OK? I have a disagreement between the OTO and test strip readings and these. Those agree that the total CL is between 5 and 10, closer to 5.
THANKS!
The directions are correct. Not sure why you would get a lower reading for Total Chlorine (TC) after applying R-0003. Are you conducting the chlorine test first and within a couple of minutes of drawing the sample? Halogens (like chlorine) do dissipate quickly, especially in small samples. Skip the pH test and any others and just test for chlorine.
Hmmm... what else? Are you using the right (9 mL) sample tube - with gradations showing .5, 1., 1.5, 2, 3 and 5 ppm in increasingly saturated (red/pink) hues? After determining FC using 5 drops each of R1 and R2, add R3 immediately to determine TC. Hold the sample tube up to northern light (the sky) or against a white background outside, or use a color corrected day lite bulb (5000 K) or photography light. Even minor degradation of light can cause 1 and 2 ppm to look similar. Have someone else make the call -- color vision differs among individuals. See if your neighbor or significant other sees the same color hues as you do.
There may be other reasons but I can see how this would be frustrating.
If all else fails: Supplement your otherwise excellent test kit with a real FAS-DPD chlorine test. The DPD test is OK but you'll love the color change in FAS-DPD (from pink to no color).
http://www.taylortechnologies.com/pr...D=1&KitID=2185
16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
