Results 11 to 20 of 25
Thread: Brown water in pool- from Iron
Threaded View
    Jun 2010
    Default Brown water in pool- UPDATE-appears water is mostly clear but brown on bottom of pool
    I purchased an 15' by 48" (4400 gallons) Intex metal frame pool this year and filled it up with well water. It looked ok at first but once it got about 1/4 of the way the water started looking brown. Not knowing any better I went ahead and filled it the rest of the way up and it is very brown. Started running the filter and it is continually changed to rust orange. I added some liquid cholirine (just under 1 gallon) and ran the filter which didn't help. I also have the intex saltwater system so I added salt but havent started running the saltwater system yet. At this point it sounds like the problem was iron from the well water. I really want to be able to swim in this thing as soon as possible but don't know what to do. I bought some HTH metal treatment stuff from walmart today. My plan was to drain about 1/4 to 1/2 the water out of the pool and refill it from a hose hooked to my kitchen faucet (has been through water softener) instead of the hose outside. I will also use the HTM metal stuff or soemthing else if you guys can recommend something?
    The pool was only 250 dollars so I don't want to spend all summer and a ton of money on getting clear water..Does a partial drainage and adding HTH metal sound like a good plan? If not what else should I do? Will I have to continue to use metal stuff all year?
    This is my first pool so I also need to know at what point if any I should add more cholorine and when I should turn the saltwater system on.
    I have the strip chemical tests and it looks like my ph is over 8 and my alkalinity is off the scale on the high end.
  1. Iron out to treat iron and tea colored water
    By Fornetti in forum --cleanup--
    Last Post: 07-02-2013, 03:56 AM
  2. Filling a small pool with iron well water
    By newbiepool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 05:24 PM
  3. iron in water (Intex pool)
    By anikahmae in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-10-2011, 03:31 PM
  4. Dark Brown water - NOT IRON!!!!
    By cans25 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2011, 11:12 AM
  5. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 03:56 PM
