Im currently running my pool on the bbb method. I have a 20k ig pool and am having a problem clearing the water up from green. Im currently using a cheap ph/chlorine only dropper test kit from the local pool store. My issue is with checking free chlorine. The method to check this on my tester is to drop the 5 drops of the reagent in and quickly compare the color to the colors on the side.
It works, but i feel its not accurate since once you drop the drops in, cap it and shake it i feel like you have almost passed the time allowed for the f/c reading.Than the color darkens to show the total chlorine reading.
Its been my understanding that the f/c reading is more important, mostly with a dirty pool
Im interested in a nice test kit also, and see the k2006 is very recommended.
I was also looking into the k2006c, which as the phone rep told me uses tritants, to determine chemical levels which he stated was more accurate than the k2006.
