Results 1 to 8 of 8
Thread: can't backwash or waste
    ohio
    Default Re: can't backwash or waste
    The handle is 180 off,
    I meant to say the pump does not sound funny and blow the fuse on filter,closed and recirculate. I did not stick my hand in front of the return to see if any water was moving when it was on closed.
    I'll take some pictures tomorrow.
    Honesdale PA
    Yeah, you need a pressure gauge. Will tell a lot. Also, NEVER run the pump with the handle between positions. Good chance you will destroy the spider gasket. If any spoke is loose the flow may lift it out of the channel then when you move to one of the positions....squash. Yes, not unusual for water to drain out the waste line with the pump off on an AG pool. Gravity and siphoning.
  1. Backwash, rinse or waste cycles loose pressure on hayward sand filter
    By Teresa Alsop in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 05:04 PM
  2. Backwash, rinse, filter blows junk back in pool, possible waste line issue
    By Cankoo's pool in forum Pool Equipment & Operations
    Last Post: 04-27-2012, 03:37 PM
  3. Backwash waste uses & routing - I need some help and ideas!
    By zephans in forum Pool Equipment & Operations
    Last Post: 07-12-2007, 03:21 PM
