Thread: Liner slipped overnight! HELP!
    Default Liner slipped overnight! HELP!
    My husband and I were installing a new liner and Happy Bottom in our 27' found AG pool yesterday. We began filling it around 6pm. We had clothespins holding it up so we could stretch or let out the liner as needed. We have a bottom drain so a hole has already been cut in the center (did that after a few inches of water were in the pool.
    This morning we discovered that as the liner was stretching, the clothespins all fell off and 1/4 of liner is hanging. Luckily no water went down into the sand so we're good there. The BIG problem is the liner is now TOO SHORT to hand over the side of the pool.
    Can anyone help us??? Can we stretch the liner in any way? Will the heat from the sun help us (it should be in the 90's today).
    May 2010
    Default Re: Liner slipped overnight! HELP!
    I used heavy duty spring clamps on mine, Anyway how much of a stretch are we talking about?
    Can you post a picture?
    It was short by about an inch or so. We rented a pump and pumped about 6" of water out, leaving about 4" in the pool. We did come back this morning and add the clamps to hold it up as we worked.
    The sun is out and warmed up the vinyl so we were able to stretch it out and get the coping on (which is probably what we should have done in the first place).
    Now, we have it all stretched over, coping is on, and we are back to filling. So far, we're back in business but I can tell you that we WON'T be filling it up at night ever again!!!
    Do you think the vinyl can slip out of the coping at all?
    May 2010
    Beaded liners can sometimes come out, but if you have a J hook or overlap you should have no issues.
    Well, thank heavens the sun came out! We were able to stretch the liner back over the side of the pool. The pool is now full and all is well. Whew! It was a bit of a nightmare but we are wiser now. Now to get the water chemistry correct and we will be enjoying our new pool with NO footprints and a Happy Bottom floor!!!
  1. AGP J-Hook Liner sagged while filling - 1/2 full, 4 foot section slipped 4-6"
    By TequilaWarrior in forum Above-Ground Pool Construction & Repair
    Last Post: 06-04-2013, 05:34 PM
  2. how to reattach vinyl liner in spot where it's slipped out of the "channel"
    By tenax in forum In-Ground Pool Construction and Repair
    Last Post: 08-06-2011, 06:44 PM
  3. Loosing too much chlorine overnight
    By douge55 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-09-2011, 08:51 AM
  4. FC not holding overnight...
    By mariner09 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2007, 05:32 PM
  5. Holding chlorine overnight
    By AndieP in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-12-2006, 04:19 PM
