So, I took my water sample to Pinch-a-Penny here in town and this is what they came up with. (they did not try to sell me anything!)
FC= 1 ppm (this is what I figured with my home test as well - I knew it was low)
pH= 7.8 (This is also what I figured at home)
Acid Demand= 2 (they are saying this is high)
Total Alkilinity = 130 (when I tested before I took the water to the store, I came up with
160 as opposed to 170 like I got yesterday)
Calcium Hardness = 500 (knew this would be high as we have been told that is why our
pool surface is degrading: the water is leaching Calcium from the marcite/plaster.)
Stabilizer = 100
Total Disolved solids = 1,900
We got a lot of rain yesterday and the day before and are in a pattern to see some significant thunderstorms daily for the next several days. We are thinking we will need to drain an inch off after todays rain. How does added rain water affect pool chemistry?
As I mentioned, we are having what we think is a small algae problem. When we brush the walls/bottom, a yellowish color billows then settles to the bottom. Obviously we need to up our chlorine (bleach). However, we don't want to dump a bunch of bleach in the pool as most likely, the pool will be drained and resurfaced starting this week. Do we increase the cholorine a bit, and keep brushing the algea/vacuuming in the interim?
A few more questions: David said he is brushing his new pool twice daily. Do we need to do that once our pool is resurfaced? And, will a regular bristle brush work or do we need to get one of those wire ones?
Also, any advice on auto vacuums? (see original post)
Any advice on switching from Chlorine to salt? (original post as well)
I noticed on another thread a guy with the sign on of BigTallDumbGuy. Maybe I'll change mine to Frizzy-haired Numbskull Gal!Thanks for all the feedback!
Kelly
