Results 1 to 10 of 56
Thread: Super high combined chlorine
    Jun 2010
    Minneapolis, Minnesota, USA
    Default Re: Super high combined chlorine
    Thanks AnnaK, that post is very helpful. I am possibly going to attempt winterizing my pool this fall for myself for the first time on our 4-year-old pool.
    May 2010
    I am ready to quit. Seem to be going backward. Still loosing about 6-7 ppm FC over night and 1-2/hour during the day. Now at close to 100 gallons bleach. This morning my CC was back up to 2. I need to have a life besides my pool! I have not allowed the FC to get below 10, keeping it most of the time between 12 - 18. Everytime I think we are making progress, i get another high CC reading! One possibility - the birds like our backyard and we have noticed a fair amount of bird droppings on the pool deck. We do cover the pool with an opaque automatic cover at night, but if droppings are getting in the pool during the day, could that be adding to my problem? I thought the sun was supposed to help the CC go dissipate quicker, so I have been uncovering it during the day - should I try leaving it covered?
    If you get an occasional bird dropping in the water, it's not going to cause the kind of CC's that you are experiencing--I have swallows that drink out of my pool and regurg stuff on a regular basis, and my CC never goes above 0.5.
    Other than keeping the pool at shock level to burn off the CC, I don't really know what to tell you to do other than try to identify where they're coming from. Is it possible that the pool surface is degrading and causing it? Are you positive that your testing methods are correct and that you're using fresh reagents? I know those questions are redundant, but I'm just muddling over your situation trying to figure out what other approach we can take. I understand your frustration and would feel the same way--but don't give up on it yet...
    Your thread in particular was one we discussed with Ben. He says if you are losing chlorine over night, then you just have to keep hammering it with bleach. I know it seems like it will never end, but one morning you're gonna get up and find that you haven't lost chlorine overnight! There is nothing else to do but keep at it. Every day consistently and you will win. (Please know that we understand your frustration. We are frustrated, too, because there is nothing new to tell you that we haven't already said. Now it is just time to stay the course and don't give up. I'm sure that doesn't help much, but there is no other easy cure. Wish there was ...
    Lehigh Valley, PA
    The major issue is to keep the chlorine up very high all the time. You've mentioned letting it drop down to 10 ppm occasionally. That doesn't help the situation. You've also allowed the CYA to creep up from 30 to 50 by using stabilized chlorine products, which means you'll need more chlorine. This is a project and a process. It's not the time to run short of or out of chlorine.
    One approach other than chlorine to kill the bacteria might be UV irradiation with a UV bulb. You could place it in the skimmer so it hits all the water being sucked through the intake. Where to get such a bulb and how much they cost I don't know. UV irradiation is used in some homes to sanitize well water, it's not just a scifi concept.
    100 gallons of bleach put into a pool without any obvious progress would frustrate the heck out of anybody and I do sympathize with you. We all do. At this point you need to exercise some extreme discipline. No swimming, no slacking off, no substitutions. High concentrations of bleach 24/7. You almost had it beat once. You can get there again.
    May 2010
    Thanks for all the encouragement. Not sure how exactly to do what you are saying i need to do. I don't think my employer would understand if I had to take a few days off so i could keep chlorine in my pool. Today is a good example, FC was 18 when I left the house this morning, I had a long busy day at work, FC is now 7. What to do?
    May 2010
    I Is it possible that the pool surface is degrading and causing it? Are you positive that your testing methods are correct and that you're using fresh reagents?
    Just received fresh reagents in the mail yesterday, and the ones I have run all the way through trying to keep up with this were new 2 weeks ago. Pretty sure my method is correct. How would I know if my pool surface (vinyl liner) is degrading? There are no areas of discoloration or other indication of damage. Guess I'll try to keep up the bleach. How safe is it to take it up close to 30 in the morning so it doesn't get as low during the day when I can't be here?
    Geez. I don't know. As fast as your cl level is dropping, it probably wouldn't stay at 30 for long but I can't tell you that it won't fade you liner. What is the highest you have shocked it to thus far?
    May 2010
    About 22, didn't stay there long though.
  1. Strange test results -- very high combined chlorine (CC)
    By Themadczar in forum Dealing with Alkalinity and Calcium
    Last Post: 08-05-2013, 10:27 PM
  2. Combined Chlorine High
    By StratDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 08:30 AM
  3. What to do next? High Alkalinity & Combined Chlorine, Well Water & Iron issues
    By lady.k in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2011, 01:17 PM
  4. High combined chlorine level won't budge
    By Carolina in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-13-2006, 08:54 PM
  5. super high chlorine
    By slowtan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-31-2006, 11:18 AM
