Back to being a little frustrated. I seem to be stuck. Still losing between 5-6ppm FC at night. Stuck at about 1ppm CC. pH - 7.2, TA - 150, CYA - 45-50 (i have a little trouble deciding exactly when I can't see that dot!). I have some time at home again today - is it best to try to keep my FC up at shock level as consistently as I can by doing the every hour check thing again today? Or is the cumulative amount of bleach going to be the same no matter what? Yesterday - partly because of working, partly because of wanting to be able to swim in the evening, we let the FC drift down to 8-10 a couple of times, then dosed it back up last night.
And how soon after I dose the pool can I check to get an accurate reading of my shock level? - I have been calculating what I need using the pool calculator, then testing an hour or so later. I am assuming that I reach shock level when I put the calculated amount of bleach in, but since I am still losing some and not checking till an hour or so later, I have never actually had a test read out at shock level. I am considering my shock level at this point to be close to 20 since my CYA is close to 50. The highest test reading I have had as been 16.
Am I missing something?
