So if your CYA is low, raise it so that you don't lose too much from sunlight during the day. You should have it at least at 30 ppm, but 50 ppm is fine as well and is more typical for pools in the sun (pools in a LOT of sun, such as Arizona, sometimes operate at 80 ppm to minimize chlorine loss, but you have to be very diligent about maintaining chlorine in such pools since it takes more chlorine to shock them to get rid of algae).
It's interesting (and somewhat comforting to my nerdy personality) that the total amount of chlorine needed was in the ballpark of that predicted based on the CYA loss, which was a rough guestimate to begin with.
Richard
My CYA was at 40 when I checked it earlier today - I had to use a little stabilized chlorine yesterday morning when i ran out of bleach. So it looks like I am good there. We do get a lot of sunlight on the pool, so I will have to see how that goes once I see whether or not I am loosing any at night. I think I will be able to get home mid-day tomorrow to check on it.
I am still loosing a bit of FC, just added 1 quart + 3 1/2 cups because it had fallen to 14.5 and the CC was back up a little over 0.5. But it is nice to be adding bleach using my pint measuring cup rather than by the jug full!
I can appreciate the comfort you receive from knowing your guestimate was in the ballpark - my personality works the same way.
The cloudiness in front of the light in my pool is nearly gone as well! YAY!!
Thanks again for your support and encouragement - not to mention your willingness to share your knowledge and experience!
