Just to clarify:
Aerating does NOT lower alkalinity (TA). It raises pH without raising TA--and nothing else can do that.
When you lower pH, you drag TA down with it. If you raise pH with soda ash or borax TA will rise--more with ash than borax. So you aerate to raise pH.
So the process is a racheting process. Lower pH and drag TA down with it. Raise pH with aeration. Repeat until TA is where you want it.
