Copper is not needed in any pool, let alone one with a SWCG. They are probably suggesting that to prevent algae growth since they are unlikely to suggest a proper FC for the CYA level in their pool.
As for proper water balance for SWCG pools, the following post has info on that:
Water Balance for SWG Pools
The main issue in SWCG pools is that they tend to rise in pH. This is primarily caused by the SWCG system increasing aeration so outgassing of carbon dioxide and possibly by some outgassing of undissolved chlorine gas as well. So turning down the SWCG on-time helps reduce the rate of pH rise.
There are two ways to get the SWCG on-time to be lower which basically means lowering the chlorine demand/usage. One is to use a higher CYA level in the 60-80 ppm range, usually 70-80 ppm. This reduces the loss of chlorine from sunlight even if one uses a minimum FC level of 4 ppm which is recommended at this CYA level for SWCG pools. The other technique is to add 50 ppm Borates to the pool since that acts as a mild algaecide so cuts down on the amount of chlorine that could be fighting nascent algae growth. The Borates also act as a pH buffer. It is also important to lower the TA level dramatically, at least down to 70 ppm if not lower. This reduces the rate of carbon dioxide outgassing (not necessary if one has a pool cover).
