Hi, and welcome to the forum and pool ownership!! Glad you're finding useful information around here--feel free to ask any questions you have. There are lots of folks with knowledge in lots of areas that are happy to help.
I can't answer all of your questions, and SWG is NOT my area of knowledge, but a general guideline is that you need to turn over the entire volume of your pool at least once daily. I have an 18 x 36 IG with a 1 hp pump and find that 6-7 hours is sufficient for my pool--but I usually just take the lazy way out and turn it on when I get up and off when I go to bed, so in reality it runs 10-12 hours during the summer. Your SWG needs to run enough so that you maintain at least 3-5 ppm of chlorine. Whether you can do that and then have it last throughout the day or whether you need to run it twice per day for shorter times will be up to you and the SWG experts around here, who I'm sure will be by soon to help answer.
I don't know where you are in the country, but I'm in Louisiana where it is very hot and very humid year round. By about mid July, my water temp is usually in the mid to high 90s, and when that happens I find that running my pump at night instead of during the day helps keep the water cooler. Otherwise, when you run the pump is pretty much your call.
