Hi guys,
Most of you know i just filled my new pool for the first time yesterday. I am keeping a close eye on everything and actually going to brush it down after this post then go to work - come back at lunch and do it all over again.
Ok - last night my reading we're
FC : 3.84
TCL: 4.04
PH: 7.6
AL: 98
CH: 180
I added some muriatic to lower the PH to 7.0 (as per the pool builders advice) added about 64 ounzes of baking soda - 4 boxes, to offset the lowering of the PH from the muriatic.
I also used Pool Calculator.com and added what I thought would bring my CH up from 180 - 260 area. I only used about 1/2 of what the Pool Calc. showed as I know "less is more" and I can always add more.
Now this morning here is my readings:
FC: 3.46
TCL: 3.52
PH: 7.2
AL: 100
CH: 185
So it appears the baking soda helped keep the AL around 100 - but the CH never went up but 5 little points.
I am going to add a little muriatic now before I brush to bring it back to 7.0 - shouldnt take much but I'll check poolcalc. I'll also add about the same amount of calcium flakes as I did last night to see if th kicks it up later.
I do have a concrete pool with marcite with little pebbles...
Any idea why the CH is not moving much? I did check it twice - with different tubes - and got the exact same number...
