OK...I add acid to lower PH which lowers TA. That much I understand. I do it in stages so as not to go to far.But how do I "aerate" the pool. I have never done that and am not sure what that means.
waskydiver, not so interested in perfect numbers as much as I am concerned that with the plaster pool, the high TA could cause problems.
To aerate, you can turn your return jet eyeballs upward to create rippling/bubbling on the surface. Or throw in a bunch of kids to play around. Anything that causes splashing will aerate.
I've never heard of aeration before, does anyone have an idea how it raises pH??
Well thats easy enough...thanks
Not sure of the chemistry, but there's a gasification process that turns an acid into a hydroxide by the removal of, I think it's CO2. Chem_Geek has the whole chemistry of it down pat.
If your T/A and your CH are both too high, it's easy to get cloudy water. For plaster pools, usually a CH of 200 to 400ppm is recommended. But if your CH goes to 500pm and your T/A rises, then you'll get cloudy water.
Most vinyl pool owners don't have high calcium so it's not a problem if T/A is higher.
The short answer is that carbon dioxide in water is carbonic acid so when you are removing carbon dioxide from the water you are effectively removing carbonic acid -- removing an acid raises the pH. For technical reasons I won't get into here, the TA does not change.
