Thread: Making solar reel
    May 2010
    Default Making solar reel
    I have a 27ft round above ground that
    is inground. Does anyone know how to
    make a solar reel or any advice. They
    look cheap and are so expensive to buy.
    Anita
    Default Re: Making solar reel
    I'm sure you could invent one that hangs just beyond the pool using 3" or 4" PVC or 1.25" iron pipe from Home Depot. You could even make your crank from the stuff. You can get a strap set for a reel without the reel and they will velcro to the tube. I would think the hardest part would be the bearings but some plastic or brass could make plain bushings for them.
  1. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  2. Solar Cover Reel
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-13-2007, 03:40 PM
  3. Solar Reel Help
    By csevel in forum Above-Ground Pool Construction & Repair
    Last Post: 06-08-2006, 09:47 AM
  4. Solar reel ???
    By JZano in forum Pool Equipment & Operations
    Last Post: 06-07-2006, 10:49 PM
  5. Which solar reel do you have?
    By cnk in forum Pool Equipment & Operations
    Last Post: 04-12-2006, 03:27 PM
