Results 1 to 10 of 17
Thread: Chlorine is GONE
    May 2010
    Default Re: Chlorine is GONE
    ok. I think it took about 20 hours last time I filled it three years ago. Thanks so much for the advice.
    Now that you're having to start over with 0 CYA, you could go ahead and use your chlorinator if you still have pucks left--just make sure that you adjust your ph as necessary, and stop the pucks when the CYA gets to your target, 20-40 ppm for most pools.
    I find that it works well to leave my chlorinator running, but set at around 1.5, then use bleach as my main chlorination method--that way, if I get lazy, or it rains, or for whatever reason I don't get to test that day, at least I know there's SOME chlorine going into the pool all the time!
    May 2010
    It has been sveral weeks since I stumbled across this forum trying to straighten out my pool. I now have a clear pool and have saved a ton of money. I just wanted to take a second to thank ALL who posted and directed me in fixing the problem. I am so lucky to have found this forum and the people here are so great to take their time and energy to help others. Thank you very much!
    Glad it all worked out for you--happy swimming....and come back to the forum when you get a chance and you can help us help others!!
    Happy Swimming.....
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
