Results 1 to 10 of 38
Thread: Salt System newbie
    Default Re: Salt System newbie
    Far from and expert, but I stayed at a Holiday Inn Express last night () - as you can't do an overnight chlorine loss, check your cl in the evening (before the pump? SWCG kicks on) to see if you are still maintaining adequate fc levels after a day of sun and use.
    No one is born knowing this stuff, so no question is a dumb one, except the one unasked!
    Quote Originally Posted by waste View Post
    Or the one repeatedly asked with hopes of getting a different answer!
    May 2010
    Oh yeah, I have made millions asking dumb questions. The problem is, I unfortunately ask them too late and it has cost me those same millions. So I have resigned myself to know my place in life as the lowest level of the food chain, dwelling down in the pond scum and looking up at catfish bellys every morning just to see the sunshine. So if my questions become too stooopid, a shoe to the back of the head usually works. Hey thanks for listening to me. It is truly a pleasure to be here.
    Dumb question number three, are those small hand held Salt Level checkers Worth their (oh no here it comes) SALT? (bad I know). I see these things on the internet for $12-$15 all the way up to $85-$100 USD. All I know is, every pool store I go to gives me a different salt reading. I am bouncing the idea around in my over impulsive feeble brain to buy my own. But logic tells me that the "LOW SALT" light is off on the unit so save yer Money.
    What say you guys?
    May 2010
    Progressing on in my quest to become the fastest pool expert on the planet, my CYA level is reported to be between 40 and 50. The Pool Store "experts" want me to go to 60-80 because of the salt system. They probably want to sell me more CYA.
    Everything I am reading says any CYA level above 50 is waste. From experience, I know that when my CYA levels were "elevated" up over 100, I had constant complaints of eyes burning. So I am extremely leery of adding any more CYA.
    Dumb question number 4 is (drum rolllllllllllll):
    What do you recommend for a CYA level for a vinyl lined AG salt system pool, and Why?
    (Is that two questions)?
    Lehigh Valley, PA
    It's my understanding that the CYA level in SWCG systems is best kept at 60-70 ppm. The 'why' is something Chem Geek will need to address.
    If you find that the pH tends to rise over time and if your pool is exposed to direct sunlight, then having the CYA in the 60-80 range, especially 70-80 ppm, has the chlorine protected more from breakdown in sunlight. Even proportionately raising the FC level to 4 ppm minimum with 80 ppm (for an SWG pool), there is less absolute chlorine loss.
    The lower chlorine loss lets you turn down the SWG on-time and that reduces the rate of pH rise (from whatever the cause -- could be more outgassing of either carbon dioxide through aeration or of undissolved chlorine gas).
    Adding 50 ppm Borates can also help reduce the rate of pH rise through two effects -- it acts as a pH buffer and it is a mild algaecide so may further reduce daily chlorine usage. It's also insurance since at the higher CYA level you want to make sure you don't have the FC drop below the minimum since fighting an algae bloom takes a lot more chlorine (higher FC level) when the CYA level is higher.
    As for eyes burning at 100 ppm CYA, that probably wasn't a direct result of the CYA but the FC probably wasn't high enough (i.e. was below 5 ppm) and that meant that the active chlorine level could have been so low as to have more chloramines in the pool and those can be irritating to the eyes. Either that or the pH may have been off (too high or low). If you find any problem at 80 ppm CYA with 4 ppm FC, try increasing the FC target to 6 ppm, but I doubt you'll need to do that since there are many, many people with SWG pools that mostly operate with 4 ppm FC and 80 ppm CYA without any issues.
    May 2010
    I have only had my SWCG for two weeks and the "official" swimming season hasn't started yet. I am watching my chemicals very closely including the pH levels. My 24' round AG pool takes direct sunlight for the majority of the day and I still consider myself to be in the Start-up mode.
    Here are my Thoughts. I am not trying to be arguementative, but I am always open for a nice discussion and maybe I'll learn something along the way.
    My overall philosophy is to keep all chemicals to a minimum. I have added seven 40lb bags of salt and I probably need to add another half to a full bag. I am at 3300 PPM of salt and should be at 3500 PPM according to the manual but the low salt light is out. I am reluctant to add more salt as the water already has a slight salty taste to it even though the internet says most humans cannot taste salt below 3500 PPM.
    I am at approximately 40 CYA and really don't understand why a Salt system requires more that a traditional Chlorine pool. For now, my SWCG runs 8 hours a day regardless, and if my current CYA levels keep a minimum amount of chlorine in the pool until the pump kicks on and adds more chlorine, then I want to believe I'm good. But hey, they don't call me the BTDG for nothing.
    As far as my previous bad experience, I can only tell you that I had my water checked repeatedly and by multiple pool stores and the response was that my water was "Picture Perfect" except for the CYA value and I still had burning eye complaints. I did drain 25 inches of water from the pool, leaving 15-16 inches of water remaining to eliminate the high CYA and still ended up with a reading of 100-110 AFTER refilling.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 09:43 AM
  2. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 12:27 PM
  3. Intex Salt Water system newbie
    By codes4food in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-11-2011, 10:06 PM
  4. Salt water magic and Intex salt water/copper ionization system
    By enchantedmountain in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 04:37 PM
