You need to keep adding the bleach until the water turns blue and the cloudiness starts to clear up. With sustained chlorine levels, it probably will take 2-4 days, depending on how consistent you are. Once it's turned blue, the cloudiness is mainly going to be dead algae that your filter will have to get out--so make sure your filter is running 24/7, and backwash it as needed when your pressure rises. Brushing your pool daily will help, but the key is to sustain that high chlorine level--don't let it yo-yo up and down. Hang in there, it's going to clear if you keep the chlorine up!!
The stabilizer is CYA--sold as "balancer" or "conditioner"...the ingredient is cyanuric or isocyanuric acid. I wouldn't worry about adding it right now--get your pool clear first and then add the stabilizer. You're going to be backwashing your filter frequently while clearing up the bloom, and the stabilizer will just wash out.
