Thread: Alternate for Borax
    Default Re: Alternate for Borax
    I understand you want to use Borax for raising pH without raising the TA as much. For those who do want to use a pH Up equivalent that raises both pH and TA, one can use Arm & Hammer Super Washing Soda instead (careful: this isn't the laundry detergent).
    An alternative to Borax in terms of rising pH with not much rise in TA is to use lye / caustic soda / sodium hydroxide. The problem is that I don't think you can find this in regular stores though you can certainly get it online from many soap-making sites and it *might* be available in a hardware store. One pound of pH Up / Soda Ash / Washing Soda / Sodium Carbonate is roughly the same as two pounds (33 ounces weight, actually) of 20 Mule Team Borax and is roughly the same as 6.2 ounces weight of Caustic Soda / Lye / Sodium Hydroxide.
    If you use lye, I would pre-dissolve it in a bucket of water first. You don't want it settling to the bottom of the pool and I think they come in pellets and not powdered.
    As for your low TA helping to stabilize your pH, you are the poster-child for this effect and I thank you for your participation in your "experiment" to help figure it all out.
    Richard
    jereece --- I think you misunderstood me. I said that in most cases it is preferable to use Borax instead of Ph Up. Most people only want to adjust the PH and not mess with the alk. So, if that is the case, then we recommend Borax.
    jereece, Chem_Geek is right: you only waste money buying pH Up! or other pool store versions of. It is chemically the same stuff as A&H Washing Soda (in the YELLOW box, in the laundry section). But A&H is lots cheaper!
    If you need to raise T/A and pH, it's a great way to do it.
  1. Alternate Pool Sanitzer?
    By Pool Newbie in forum General Interest
    Last Post: 08-31-2012, 09:24 PM
  2. pH between 6.8 and 7.2 (ish)... how much Borax?
    By mastamoon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2012, 04:33 PM
  3. How much borax
    By lstinthot in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-15-2011, 02:50 AM
  4. How much borax?
    By Rangeball in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-07-2006, 06:17 PM
  5. Unbiased pool chemistry info. Alternate source.
    By JohnT in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-18-2006, 01:49 AM
