Results 1 to 9 of 9
Thread: Solar Panel Connection layout
    Default Re: Solar Panel Connection layout
    You mean make the T into a "Tree" so that all three panels get an input feed and all three go to output. This can be done, just will require a longer feed from the "Tree" to the third panel and longer output from Left bottom panel to output "Tree" - all due to layout and space limitations. White PVC schedule 40? or the gray PVC?
    This setup could end up adding a 4th panel at some point if we don't get enough warm water from this, but I think with a normal summer, we should be able to do fine with the three panels.
    The pool prep, planning and the maintc is my "baby" - the hubby just helps with the grunt work and relaxes in it when its ready. Thanks - getting this straight in my head by running it past others really helps.
    Poughquag, New York, USA.
    I think that is what I would do. But, the company you bought these from must have some plans, suggestions for multiple panels. What do they say?
    Its a pool supply, they don't really offer any help here. They suggested we roof mount, when I told them how far away and that it would have to cross a driving area, it was Hmmm, don't know. I like my post mount idea, just needed to have someone tell me I'm not crazy and to help me get efficiency tuned up. Thank you so much.
  1. Solar Panel Recommendations
    By jsnyder2914 in forum Pool Equipment & Operations
    Last Post: 08-10-2011, 11:08 PM
  2. SunGrabber solar panel....
    By BullDean in forum Pool Equipment & Operations
    Last Post: 06-19-2006, 11:01 AM
  3. Solar Panel - too much air in system
    By jmcst25 in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 08:33 PM
  4. solar panel
    By marchbreak in forum Above-Ground Pool Construction & Repair
    Last Post: 05-03-2006, 08:13 AM
  5. Solar Panel?
    By csevel in forum Above-Ground Pool Construction & Repair
    Last Post: 04-21-2006, 05:50 PM
