try to make this short...am now emptying pool after not being able to clear water last year...clear until you got in then got cloudy...used flocculants and chemicals...balance was perfect except for these floating particles...now the bottom seems rough, walls not slimy...what can I use to clean entire pool...liner is only 2 years old so replacing that is not what I would like to do...can I use regular soap, maybe with some chlorine added...need help fast...pool is almost empty.
