Results 1 to 10 of 37
Thread: Famous Chlorine
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default Re: Famous Chlorine
    ok will try to answer
    No never added a chlorine remover
    No floating algae
    Never added any yellow out or yellow treat
    Did not take any readings last fall when closed thus unsure of cya reading
    Do not have copy of initial readings but when pool place opens in morning will see if we can get copy-ok
    Today added 6x1.42 gals of 6% and was able to get a chlorine reading with the strips as a quick check about 30 minutes after.
    3 hours later none
    Added another roughly equivalent to 20 ppm - checked and was able to see on strip
    3 hours later none on strip but on chemical tester appears free chlorine was betrween 2-3.
    Will hit it again once done mowing the lawn
    Have added areator or will plan on treating every 3 hours until bed and then give you complete set of readings in morning-OK
    Last shock it did load up the filter so something came out of the water
    Good. Use the tester instead of strips. Keep slamming it with bleach often and watch filter pressure. Backwash as needed. Did you read that other thread I linked above? Sorry you're having such a hard time. This isn't usual. Most of the time it clears up pretty quickly. Make yourself a note to check all levels upon closing this fall in case you need them next spring. That is good advice for everyone.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
