No, if you double the sample from the pool, then you actually have to divide your result by 2 instead of multiplying.
The sample from the pool should be diluted 1:1 or 1:2 with water that doesn't contain chlorine for the test to work--and even then you're going to lose some accuracy with each dilution...
