Results 1 to 9 of 9
Thread: no pressure on recirculate
    May 2010
    Default Re: no pressure on recirculate
    Its low return flow, but I'm going to replace gasket in pump basket and o-ring on vari-flo head to sand filter base. And I'll let you know how it works. Thanks, Timmy
    Smile Re: no pressure on recirculate
    Hey Timmy welcome here!!!
    Al's got you covered on where to start looking. As you find out more, keep us informed and we'll not only help you nail down the problem but, also, tell you what needs be done to fix it - so you can decide whether or not you want to tackle it yourself
    May 2010
    Unhappy Re: no pressure on recirculate
    OK I've changed gasket for pump basket and o-ring @ the vari-flo valve and base. also checked all conections from pump to the filter.started the pump up on filter, window showed no bubbles yeah. But awhile later hours rechecked, guess what saw my old friends bubbles. Rechecked all connection all threads no water leaks maybe a few drips around vari-flo head and sand base. Even checked drain plugs on pump basket. restarted everything looks good for awhile then bubbles come back and water level in basket dropped about 1/4 of inch and all kinds of bubbles. Note that when I started my pump in filter guage reading 24PSI any suggestions.
    Honesdale PA
    Sure sounds like an air leak somewhere and that somewhere would be on the suction side, not the pressure side so concentrate on the suction side. It also sounds like a very tiny leak and that's all it takes. You can try smearing vaseline around the pipe joints as it is thick and if you have a hairline crack that should seal it. Then fix it when you find it. Don't leave the vaseline on O-rings or gaskets for any period of time. Vaseline is cheap and cleans off easily. Also, is yours an above or in-ground pool? Reason I ask is for access to the skimmer basket connection. Under a deck can be a dog.
    May 2010
    its a inground pool . i noticed this morning that when i turned the pump off i had a little stream of water shoot out the side off sight cover at the pump. do i need to glue the gasket in the basket for it to seal proper. also heard small sound of air around the handle at the sand filter, don't know if thats where air was in the basket. just some things i wanted to shoot out there to you. again thanks for the info. if i was to have to glue the gasket what type of glue would you use.
  1. What does Recirculate do on my pool filter?
    By bonehead in forum Pool Equipment & Operations
    Last Post: 06-28-2013, 04:32 PM
  2. Recirculate?
    By jmjbj_h in forum Dealing with Algae & Slime
    Last Post: 05-04-2007, 11:30 PM
  3. Poly 60 in pool. Filter or Recirculate?
    By jdolby in forum Dealing with Algae & Slime
    Last Post: 06-01-2006, 03:39 PM
  4. Pressure guage under pressure!
    By rustypixel in forum Pool Equipment & Operations
    Last Post: 05-02-2006, 02:56 PM
