Okay, I've got a 24' diameter above ground pool. Last year because of some maintenence, I replaced the sand in the filter. I don't know if this is related to my problem, but trying to cover all of the bases so that some of y'all might be able to help! This spring, I uncover the pool, fill with water, get everything running. Of course, it's spring in Georgia, everything is blooming and seed pods, etc. are falling, making keeping the skimmer clean a job and a half. Okay, what happens is that the pump will be running, getting a good strong return, life is good. Go back a couple or few hours later, hardly any return. At first, I figured the pollen was the culprit, so I'd backwash, and then the return would be strong again for a few hours. So, I decided to just shut the pump off for a minute. Turn it on, strong return for a few hours. Anybody have any ideas? This last deal has pretty much taken pollen plugging the sand filter out of the equation because I merely turned to pump off for maybe thirty seconds then back on!!
